JOIN FISHNET AND NLCD
1236
01-04-2023 04:45 PM
SarahRadel
Greeting's.  I am trying to merge my fishnet with NLCD data.  Can someone point me in the right direction?
Thank you 🙂
Taren_Esri
@SarahRadel
You can also try doing Zonal Statistics as Table, then Join the results back to your fishnet feature class. Good luck!
Taren_Esri
Hi @SarahRadel
Do you mean you are trying to sample values from your NLCD dataset to each grid in your fishnet? If so, you want to use the Zonal Statistics tool. You can read a bit more about how the tool works here
SarahRadel
Thank you Taren. I initially did run zonal statistics, but it gave me a skewed image without an attribute table. I will read more up on how it works. Thank you again.
Taren_Esri
@SarahRadel
