Issues Copy & Paste Layer Properties (ArcGIS Pro 3.4)
2451
6
11-13-2024 04:54 AM
OscarFitzpatrick
Hello,
I've been trying out the new copy and paste layer properties feature in ArcGIS Pro 3.4. For anyone who isn't aware, you can now paste the properties of a layer to another, or a subset of properties of a layer to another (e.g. you can copy the pop-up configuration of one layer, to another).
This is a great feature, and works quickly - but I have found that feature becomes unavailable after a running the function a couple of times. Has any else ran into this?
I've found that the function is available again if you close your map and re-open it, which is a workaround for now.
OscarFitzpatrick
ps: Does anyone know if this feature is available through arcpy or ArcGIS API for Python? Given that you can only copy and paste the features between individual layers, it would be helpful to be able to loop through your map and programmatically apply properties using this feature.
ChrisUnderwood
Hello @OscarFitzpatrick , no problems for me so far. I can Copy & Paste Properties between my Layers without any obvious limit.
Are you pasting any particular Property, eg All, Symbology, Labelling etc. And are those properties set to any particular values in either the source or target ?
OscarFitzpatrick
I was pasting pop-ups in particular, speaking with a colleague we seem to encounter a similar issue when renaming multiple layers in quick succession. I'm not sure what's happening under the hood, but maybe we're running into a temporary buffer limit of some sort?
SH_DH
Hi - I run into the same issue. I can't only use 'paste properties' so many times until it's greyed out. It still functions if using the tool from the 'Edit' tab, but that eliminates pasting just a subcategory, such as Symbology/Label/etc.
Michael_Kraus
Same issue for me in Pro 3.4.4.  Works about 4 times then the paste properties context menu is greyed out.  I only want to paste symbology, so don't want to use the option in the ribbon (which is not greyed out).
Confirming also that closing the source map (the one I am copying from) and re-opening does re-enable the feature for a couple more tries.
AndrewWilson1
Same issue for me in 3.5.4.
