Issue with "Split Line at Vertices" Tool
840
04-22-2023 05:31 PM
Omar_A
by Esri Contributor
I am experiencing an issue with the "Split Line at Vertices" tool when using it within ModelBuilder. Specifically, the tool fails when connecting the input variable, and ArcGIS Pro shuts down afterwards.
Thank you for your help in resolving this issue.
DanPatterson
MVP Esteemed Contributor
Split Line At Vertices (Data Management)—ArcGIS Pro | Documentation
featureclass in a geodatabase? on a local drive?
shapefile?
multipart or singlepart?
Can you use the tool outside of modelbuilder on the same fgc without issue?
... sort of retired...
