Issue with JSON string
1854
06-07-2022 08:31 AM
MM598
Hi, I have been using the JSON string on this website: https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/web-map-printing-with-arcpy-mp.htm#ESRI_SECTI.... It has worked fine until a week or two ago. Since then, the string has not worked. After it is introduced, I try to perform a function with it, and then it returns "RuntimeError: Failed to create layer from service at http://. . ." When I go to the website, it says "503 Service Temporarily Unavailable." The unavailable website is the one found in the JSON string, http://maps1.arcgisonline.com/ArcGIS/rest/services/USA_Federal_Lands/MapServer
What is going on with the JSON string? Will the service be back up soon?
Tags (3)
MM598
JoshuaBixby
I suggest changing your title because the issue has nothing to do with JSON, the issue is that the maps1.arcgisonline.com site is offline.  Have you called Esri support about that site being down?
MM598
I'll repost in the ArcOnline community with a different heading. Unfortunately I am not the person authorized to call ESRI Support in my organization. Thanks.
MM598
