You can do it via code.
import arcpy
#Reference the Project document from within PRO
aprx = arcpy.mp.ArcGISProject("CURRENT")
#Reference the layout
lyt = aprx.listLayouts("your_layout_name_here")[0]
#Get the Map Frame
mf = lyt.listElements("mapframe_element", "your_mapframe_name")[0]
extent = mf.camera.getExtent()
polygon = extent.polygon
You then have a polygon object that you can work with.
Note that this code just grabs the extent, if the map frame is rotated, the extent doesn't match what you see on screen.
Using tools in ArcToolbox
Create Fishnet (Data Management)—ArcGIS Pro | Documentation
import arcpy
#Get the Map Frame
Hi Mark,
Can you please indicate how to save the extent as a feature class? I tried InsertCursor but it didn't accept the polygon object, it requires list of floats instead.
Many thanks,
Katerina.
This worked great! Thank you!
I realise there is a solution here but wanted to add a script for use in an ArcGIS Pro which creates a new polygon row in a feature class based on the current extent. The script also adds a scale from current extent to a field called SCALE (it will need to exist in feature class for it to work).
This is particularly useful for users who are trying to build map books using data driven pages.
Users will just need to create a script within a toolbox and add a parameter that is a feature layer type so that users can input a feature class for it to work. Here is script:
# Import system module
import arcpy
# Input parameter for feature class name
feature_class_name = arcpy.GetParameterAsText(0)
# Extracting the geodatabase path from the feature class name
geodatabase = "\\".join(feature_class_name.split("\\")[:-1])
# Ensure overwriting of output data
# Select the current project map
# Select the current map layout
map_layout = aprx.listLayouts()[0]
# Extract the extent of the selected data frame
map_frame = map_layout.listElements("MAPFRAME_ELEMENT")[0]
extent = map_frame.camera.getExtent()
# Append a new row to the existing feature class
arcpy.management.Append([polygon], feature_class_name, "NO_TEST")
arcpy.AddMessage("Polygon appended to the existing feature class.")
# Get the current layout scale
current_scale = map_frame.camera.scale
# Check if the SCALE field exists
field_exists = False
for field in arcpy.ListFields(feature_class_name):
if field.name == "SCALE":
field_exists = True
break
if not field_exists:
arcpy.AddError("SCALE field does not exist in the feature class.")
else:
# Update SCALE field for the newly added row
with arcpy.da.UpdateCursor(feature_class_name, "SCALE") as cursor:
for row in cursor:
row[0] = current_scale
cursor.updateRow(row)
arcpy.AddMessage("SCALE field updated for the newly added record.")
Hopefully this saves someone some time 🙂
