Is there a geoprocessing tool for inserting a new row into a standalone table?
For example, in model builder, I want to add a new row to this non-spatial table:
ArcGIS Pro 3.0.3
Thanks.
As Dan said, there's no out of the box tool. If you need that functionality in Model Builder, you have to create that tool yourself.
Below are two quick examples. You can save that script as a Python toolbox (.pyt), load that into ArcGIS Pro, and then drag the tools in to your model.
# -*- coding: cp1252 -*-
import arcpy
class Toolbox(object):
def __init__(self):
self.label = "Utility"
self.alias = "utility"
self.tools = [InsertRow, InsertRowIntoTableA]
class InsertRow(object):
label="Insert Row"
description="Inserts a row into a table"
def getParameterInfo(self):
parameters = [
arcpy.Parameter(name="in_table", displayName="Table", datatype="DETable", parameterType="Required", direction="Input"),
arcpy.Parameter(name="row", displayName="Row", datatype="GPValueTable", parameterType="Required", direction="Input"),
arcpy.Parameter(name="out_table", displayName="Edited Table", datatype="DETable", parameterType="Derived", direction="Output"),
parameters[1].columns = [
["GPString", "Field"],
["GPString", "Value"]
return parameters
def updateParameters(self, parameters):
par = {p.name: p for p in parameters}
in_table = str(par["in_table"].value)
# reset fields if no table is selected
if in_table == "None":
par["row"].value = None
return
# get fields from the table
target_fields = [
f.name
for f in arcpy.ListFields(in_table)
if f.type not in ("OID", "GlobalID", "Geometry")
# get currently loaded fields
current_fields = []
if par["row"].value is not None:
current_fields = [
f
for f, v in par["row"].value
# if these don't match, a different table was selected -> change fields
if current_fields != target_fields:
par["row"].value = [[f, None] for f in target_fields]
def execute(self, parameters, messages):
# get fields with user input
row = [
[field, value]
for field, value in par["row"].value
if value not in ('', None)
fields, values = list(zip(*row))
# insert the new row
# all values are str, but the InsertCursor should take care of the conversion
with arcpy.da.InsertCursor(str(par["in_table"].value), fields) as cursor:
cursor.insertRow(values)
# set the output parameter
par["out_table"].value = par["in_table"].value
class InsertRowIntoTableA(object):
label="Insert Row into TableA"
description="Inserts a row into TableA"
parameters = [
arcpy.Parameter(name="in_table", displayName="TableA", datatype="DETable", parameterType="Required", direction="Input"),
arcpy.Parameter(name="ID_A", displayName="ID_A", datatype="GPLong", parameterType="Required", direction="Input"),
arcpy.Parameter(name="TEXT_A", displayName="TEXT_A", datatype="GPString", parameterType="Required", direction="Input"),
arcpy.Parameter(name="out_table", displayName="Edited TableA", datatype="DETable", parameterType="Derived", direction="Output"),
return parameters
# get the values
fields = ["ID_A", "TEXT_A"]
values = [
par[f].value
for f in fields
No. You would have to create a table, add your stuff and merge. Python scripting would allow for an InsertCursor to update an existing table
import arcpy
def __init__(self):
label="Insert Row"
parameters = [
return parameters
return
target_fields = [
f.name
current_fields = []
current_fields = [
f
row = [
[field, value]
parameters = [
return parameters
# get the values
values = [
par[f].value
for f in fields
