Is the Stealth Mouse (attached file) supported in ArcGIS Pro ?
1952
06-20-2022 12:01 AM
AgeosUtilisateur1
Please I have a question :  is the Stealth Mouse (attached file) supported in ArcGIS Pro ?
Thanks a lot,
DanPatterson
MVP Esteemed Contributor
Navigation options—ArcGIS Pro | Documentation
Use ArcGIS Pro with a keyboard—ArcGIS Pro | Documentation
There a no mouse devices listed in requirements.  If the mouse can be programmed, particularly to keyboard shortcuts, then have a look at the above.  (there are more shortcuts, the above is just a sample
An "Idea" exists for this mouse as well
ArcGIS Pro Image Analyst: Support for Stealth Mous... - Esri Community
with some support but none indicated whether it worked or not
... sort of retired...
RobertBorchert
Honored Contributor
Other than the joystick it is kind of fluff. 3D Application in ArcGIS are designed to work with typical mice.
I don't see any reason why it would not work.  My gaming mouse has more buttons and works just fine.  Though I don't bother to program them for GIS as I program instead the keyboard shortcuts
BarbaraSchneider2
