Is it possible to vertically center text in a rectangle text in ArcGIS Pro?
33060
37
11-29-2018 11:52 AM
ChrisDawson
I am using ArcGIS Pro to update some of our old poster maps. I am trying to dynamically label individual detail maps on the poster. I have a title for each of the detail maps in a "rectangle text" item. I'd like the text in this item to be vertically centered. Based on the Format Text dialog, this seems to be possible. In fact, it works for regular text, say with a marker background, but not for rectangle text items. Am I missing something?
MarkBockenhauer
you could try stack and horizontal alignment.
ChrisDawson
Ah. Thanks. If I were labeling in the map, that would probably work. Unfortunately, I'm trying to work with a layout.
MarkBockenhauer
oh.. OK  well I am currently testing a development version of ArcGIS Pro (2.3) and it appears to be working... so perhaps a bug in your version.
You do have to click the Apply button to see it change in the layout.
ChrisDawson
Hm. Can you check to see if the vertical centering works. I've already confirmed the horizontal...
MarkBockenhauer
ahh I need to read better...  "vertical aligned"    I see the same.  Not working the way one would think it should.
ChrisDawson
And here my hopes were up that the beta would solve all my problems...wah, wah, wah...
MichaelVolz
Esteemed Contributor
Thanks for making ESRI aware of this issue, though.
TomBole
In the meantime, you can use Offset X and Offset Y to position text within the rectangle. Unfortunately, you'll need to make adjustments for each text element based on size of rectangle and text string.
ChrisDawson
Yes. Thank you. I've used that work around. It'll do for now, but is less than ideal on a programmatic basis, especially in map series.
