Is it possible to run just one group in modelbuilder
3439
05-09-2023 10:13 AM
PLadd
I have created 4 groups within a model in ArcGIS Pro and I need to test the tools in just one of the groups.  Is it possible to run only 1 group on a model?
I noticed when I run the model with just one group selected, the order of operations seems to jump around between groups and I'm guessing it's because of the order in which these objects were dropped onto the model palette (I have no precondition parameters).
DanielFox1
Hi @PLadd
The best way is to remove the input link to the other groups in your model this will allow you to test the one model you need. Alternatively, have a separate model builder tab/workspace with this one model.
If you have other groups that feed into each other I would recommend preconditions to ensure all your models run in an order.
PLadd
Thanks for the reply @DanielFox1 .  Can you clarify what this means?  "remove the input link to the other groups"  I don't have any connectors between the group, if that's what you mean.  See image below showing 2 of the grouped models in the model tool.  Thanks.
DanielFox1
Hi @PLadd
In the screenshot you provided if you only want to run the group/model on the left then with the group/model on the right remove the input at the start and reconnect when needed. You can see in my example the greyed out workflow as the initial connection has been broken.
I have included below a document which refers to setting a model parameter order, it was written for ArcDesktop so is slightly outdated but may still assist with any future work you are conducting.
6-Setting model parameter order
I hope this clears up what I meant in my previous message.
PLadd
I am finding that selecting the last Geoprocessing tool in the group, right-clicking and choosing Run works best for me.  This will run all of the tools in the group above it and allow me to test just the tools within that group.
