Is it possible to publish my working network analysis route dataset and route layers to ArcGIS online for public use without Enterprise?
332
2 weeks ago
ScottFraser_Key-West
I've created a functional route map in Pro, using a newly created dataset for roadways within our industrial park , many of which don't appear in Esri's datasets.
Seeking for a way to make this service useable to visitors by publishing it online, but don't have Enterprise. Is there a way to publish my dataset and route layers online for the public to use?
Thanks
Laura
by MVP Regular Contributor
You can publish your dataset from ArcGIS Pro as long as you're signed into ArcGIS Online (AGOL). It doesn’t have to be just a shapefile—any feature class in your project can be shared as a hosted feature layer.
From Pro, you can publish your data and then build a web map that can be shared publicly:
https://doc.arcgis.com/en/arcgis-online/manage-data/publish-features.htm
That will allow others to view and interact with your data online.
However, if your goal is to use this as a custom routing solution (i.e., using your own road network for directions/route solving), that’s where limitations come in. ArcGIS Online alone won’t host custom network analysis services. For that capability, you typically need ArcGIS Enterprise with Network Analyst Server to publish a custom routing service:
https://pro.arcgis.com/en/pro-app/latest/help/analysis/networks/publish-custom-routing-services.htm
Laura
Yeah, that's the only answer I was finding. Indeed, I was hoping to use my road network and dataset as a publicly available custom routing solution, absent Enterprise.
Was hoping for other options.
