Is it possible to change the font and color of county names listed on the map in ArcGIS Pro 3.1.0?
1238
8
12-16-2024 01:38 PM
RajeshMangal
We need to change the text font and color of the county names listed on the map to different color (from gray to Black) to be color blindness compliant. Any suggestion, how to do that?
Ed_
by MVP Regular Contributor
if you are talking about county names as Labels then yes. The link below help, cheers.
Labeling basics
Question | Analyze | Visualize
Ed_
Labeling basics
RajeshMangal
Thanks for quick response. Will try and let you know how it goes.
Ed_
Simple labels can work too
Bring in a county later that has names bas attributes
Make the boundaries themselves hollow with no outline if you just want the names to show
Then play with the labeling properties
Good luck 🙂
RajeshMangal
Thank you. This worked. Appreciate your help.
ThomasHoman
If you have the County data as a layer in your map you should be able to have full control yourself - https://www.census.gov/geographies/mapping-files/2024/geo/bas/2024-bas-shapefiles.html
If you are receiving the County boundaries via a base map or other online source, you will likely have much less control over the colors.
Hope this helps
Regards,
Tom
RajeshMangal
The county data and names are via the base map where we just added our metadata to select our required counties and needed those names bolder and more readable.
Ed_
I would go with annotations then and turn off the basemap labels if need be
BarryNorthey
There are a few sources for county boundaries so its not clear exactly what data source you are using. Some provide the user with full control over labeling, etc.
Since you are dealing with creating products for color blind users, check out the Color Vision Simulator found under the View tab -> Accessibility group. It was introduced at 3.0.
