Is it a Conda Issue?
5016
6
01-24-2021 06:50 AM
MarcSwartz
How do I trouble shoot this problem?
ArcGIS Pro 2.7 Windows 10 Pro
From a Python Command Prompt
conda --version
returns this
(arcgispro-py3) C:\Program Files\ArcGIS\Pro\bin\Python\Scripts>conda --version
File "site-packages\PyInstaller\loader\rthooks\pyi_rth_multiprocessing.py", line 7, in <module>
File "c:\apps\conda\lib\site-packages\PyInstaller\loader\pyimod03_importers.py", line 627, in exec_module
File "multiprocessing\__init__.py", line 16, in <module>
File "multiprocessing\context.py", line 6, in <module>
File "multiprocessing\reduction.py", line 16, in <module>
File "socket.py", line 49, in <module>
ImportError: dynamic module does not define module export function (PyInit__socket)
[15460] Failed to execute script pyi_rth_multiprocessing
Tags (1)
DanPatterson
MVP Esteemed Contributor
I don't use a clone.  So I suspect that your clone is missing the administrative stuff that the base environment has, or your permissions don't enable you to run/use the admin environment.
You haven't indicated what you want to do?
You won't be able to update conda in any event.
You can install packages in your clone when you are logged in and using the clone.
Perhaps some clarification would help.  The fact that you can't determine the conda version doesn't indicate a problem because the Scripts folder is before the path of the clone
C:\arc_pro\bin\Python\Scripts    # proenv.bat location
C:\arc_pro\bin\Python\envs\arcgispro-py3   # my only environment
C:\arc_pro\bin\Python\envs\...the clone ...    # in general, this is what you control as a non-admin
... sort of retired...
DanPatterson
You should be running proenv.bat
Make a shortcut
  Target :  C:\arc_pro\bin\Python\Scripts\proenv.bat
Start in:  C:\arc_pro\bin\Python\envs\arcgispro-py3
where arc_pro is your install folder for ArcGIS Pro.
(arcgispro-py3) C:\arc_pro\bin\Python\envs\arcgispro-py3>conda --version
conda 4.3.27
It doesn't look like you have the base/main pro environment activated which would be in
C:\YourInstallFolder\bin\Python\envs\arcgispro-py3
(arcgispro-py3) C:\arc_pro\bin\Python\envs\arcgispro-py3>conda info --envs
# conda environments:
arcgispro-py3         *  C:\arc_pro\bin\Python\envs\arcgispro-py3
root                     C:\arc_pro\bin\Python
>conda info --envs
MarcSwartz
First off, Dan thanks for responding!
Current Environment
In a command window I ran this
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3>"C:\Program Files\ArcGIS\Pro\bin\Python\Scripts\proenv.bat"
then tested with conda --version
issue persists
Of note:  When I run under an Admin account I do not have this problem, but it is against out IT policy to operate software under an Admin account.  And the Clone I create under an Admin Account is not accessible as a General user (local account?)
DanPatterson
MarcSwartz
Dan,
Fixing Software issues is a process of elimination.  You have eliminate one of my question.  Is it a Conda Issue? Answer is No.  You have also mirrored one of my concerns "So I suspect that your clone is missing the administrative stuff that the base environment has
Thank you for your time and the next path for my investigation.
MarcSwartz
Dan,
Just to let you know, here are the steps we used to Clone the Default Python environment as a non-Admin user.
Open a CMD window at C:\Program Files\ArcGIS\Pro\bin\Python\Scripts as this was the only location where conda would run.  Strange, but it is a very restricted IT environment out of my control.
Activate the default python environment
C:\Program Files\ArcGIS\Pro\bin\Python\Scripts>activate arcgispro-py3
Clone the default python environment
(arcgispro-py3) C:\Program Files\ArcGIS\Pro\bin\Python\Scripts>conda create --clone arcgispro-py3 --name C:\Users\YourProfile\AppData\Local\ESRI\conda\envs\agp2p7_py3_clone2
After the cloning was done we activated the new clone and installed a python package with pip
(arcgispro-py3) C:\Program Files\ArcGIS\Pro\bin\Python\Scripts>activate C:\Users\YourProfile\AppData\Local\ESRI\conda\envs\agp2p7_py3_clone2
(C:\Users\YourProfile\AppData\Local\ESRI\conda\envs\agp2p7_py3_clone2) C:\Program Files\ArcGIS\Pro\bin\Python\Scripts>pip install laspy
Note to others:This is a non standard method that happend to work for the restricted IT environment I operate in.
The YourProfile is where you need to change to what you use on your computer.  Direct copy and paste will not work.
DanPatterson
Although newer versions of conda are supposed to behave better with pip, be careful.  if you can add conda-forge to your channels to search.  We had similar issues when I was teaching and we ended up installing what we needed in the base environment to avoid the whole clone thing.  It worked well.
Many an article has been written by my previous incarnation on the clone wars  😉
Clone... ArcGIS Pro ... for non administrators - GeoNet, The Esri Community
