Is Filtering/Setting Definition Queries on Map Services Supported?
1409
01-14-2022 05:33 AM
Matt-Huser
I was expecting ArcGIS Pro to behave like ArcGIS Online Web Maps.  When I bring in any Map Service, I can't figure out a way to change the definition query on layers.  Is this not supported functionality?
Example Map Service that can be filtered in a Web Map but not in Pro 2.8.3
https://livefeeds2.arcgis.com/arcgis/rest/services/GEOGLOWS/GlobalWaterModel_Medium/MapServer
JayantaPoddar
You could add the respective layer directly to ArcGIS Pro.
e.g.
https://livefeeds2.arcgis.com/arcgis/rest/services/GEOGLOWS/GlobalWaterModel_Medium/MapServer/0
Definition Query should work with these layers.
Think Location
Matt-Huser
Thank you!  Yes, I can confirm this works but adding a single layer at a time is not an efficient workflow.  I'm curious if this discrepancy in behavior between the Web Map and ArcGIS Pro when working with Map Services is expected behavior or a bug.
LindsayWithers1
Was there ever any resolution on this for you @Matt-Huser? We've run into the same issue (it's not efficient to bring every one of the layers in the map service into Pro separately).
