Invalid geometry when creating features
1599
04-05-2022 06:10 AM
by Anonymous User
Not applicable
I have an issue when trying to create features with z-values using the Utility Network. In this case, I am trying to create manholes from the Structure Junction > Vault group. I set the elevation in the elevation group of the edit tab. If I put in a whole number (e.g. 620), it will create the feature without problems. It will also take 1/4 values (e.g. 620.25, 620.5, 620.75).  When I try to set it to a number with any other decimal value (e.g. 620.37), I get an error:
Failed to create Manhole.
Invalid Geometry [
Rule name: StructureJunction - Manhole
Elevation Attributes,
Triggering event: Insert,
Class name: StructureJunction
I did not have this issue with the stormwater manholes of the structure junction group, which use the same data type (double) for elevation.
KimberlyGarbade
It looks like you are violating the "StructureJunction" constraint rule someone wrote/applied to your Manholes feature class
Either you are violating a Constraint Rule directly (when this happens you are not allow to complete your edit and it is discarded and the database rolled back to a pre-edit state) or your edit is triggering an update to another asset class that is violating a constraint rule.
You can review your rules by right clicking your layer name in the ArcGIS Pro TOC > Choosing Design > and clicking Attribute Rules.  You need the correct permissions to edit them (and if your layers are coming from a service you won't be able to edit them), but at least you can see them...Someone will have to change the rule to allow the edit.
Not much help I know but (maybe) helpful information.
by Anonymous User
Not applicable
Thank you for you reply. I checked the Attribute Rules and the only rule regarding z-values was to round it them to 2 decimal points. I'm creating these Structure Junction > Vault > Manhole asset types in both storm and sewer. This problem is only occurring in the sewer editing even though they follow the same attribute rules regarding elevation.
