Intended geodatabase types for unregistered tables and feature classes
483
01-08-2024 12:17 PM
Bud
Esteemed Contributor
ArcGIS Pro 3.2.1
Create Unregistered Feature Class:
Creates an empty feature class in an enterprise or mobile geodatabase. The feature class is not registered with the geodatabase.
Create Unregistered Table:
Creates an empty table in a database or enterprise geodatabase. The table is not registered with the geodatabase.
The two tools perform similar operations: They create an unregistered object in a geodatabase. But the docs suggest they're used in different types of databases.
Is that correct? Or are those docs misleading?
For example, is there a reason why we can create an unregistered feature class in a mobile geodatabase, but shouldn't create an unregistered table in a mobile geodatabase? Both tools seem to work in a mobile geodatabase without issue.
