Importing 3D models and units
2024
03-17-2021 09:43 AM
HanaSuckstorff
Hi folks! I'm trying to import an OBJ file into ArcScene (local scene) in ArcPro version 2.7.1. I originally imported the OBJ mesh into SketchUp, where I set the unit at meters. I then exported the file as an OBJ and imported into ArcScene. As the basemap is in meters, a model in meters should be the proper size. But as you can see from the screenshot, it's much too small. What might account for this? How can I make this work?OBJ Import Screenshot March  17.pngOBJ Import Screenshot March 17.png
Tags (3)
DanPatterson
MVP Esteemed Contributor
does the imported file have a defined coordinate system.
Your display units are in decimal degrees, what are your map units?  What is the coordinate system of the map?
... sort of retired...
HanaSuckstorff
Thanks for your response. I set the coordinate system of the OBJ at WGS_1984_Web_Mercator_Auxiliary_Sphere, which is the coordinate system of the map, when I imported it into ArcScene. The map units are whatever the standard units are for the ArcScene basemap. I did try fiddling with the OBJ in SketchUp using architectural units. When I imported this file into ArcScene, it was significantly too large.
