Import a previously created file Geodatabase
2953
07-27-2023 05:19 PM
ChrisGeraghty
Hi. I received a file geodatabase via email. I have downloaded and unzipped the folder. How do I bring the import/merge/load this geodatabase folder into an active ArcGIS Pro? (When I try to 'Add Data' or 'Make a Connection' the geodatabase folder appears to be empty.
Appreciate any guidance on this -- thanks!
DanPatterson
MVP Esteemed Contributor
if a *.gdb is in the folder of the zip file, then
... sort of retired...
