Image Classification Wizard Crash
1422
12-04-2024 03:06 PM
IanHuerta
In the Image Classification Wizard, after succeeding on the previous steps I keep getting to the Classify Pane and name my Output Classified Dataset.
Every time I run it ArcGIS pro tells me that the application has stopped working.
I then am prompted to send my crash report.
I've run it 3 times checking to see if my filepath was too long. This does not seem to be the issue.
Any ideas?
-Ian Huerta
DanPatterson
a path that is too long may not be the issue, but the destination location and/or filename may be (eg local folder, network folder, a prohibited onedrive folder etc etc)
... sort of retired...
IanHuerta
Would using the D:\ drive be an issue?
-Ian Huerta
DanPatterson
you could test by creating a folder in C:\Temp and specifying a *.tif output filename for the output raster
