Issue on ArcGIS Pro Ortho Mapping Block Adjustment
1859
06-15-2022 12:26 AM
jantolihao1
Hi All,
Thank you in advance for those who will give hints and/or ideas on how to resolve this issue.
I am currently trying to create orthomosaic using Ortho Mapping in ArcGIS Pro using my satellite images. However, I am having trouble in block adjusting my images and keep getting the error below:
"Error 001934: The adjustment method is not applicable to the mosaic dataset."
"Failed to execute (ComputeBlockAdjustment)"
I found a documentation in Esri's website to use RPC method as transformation type for mosaic dataset created with satellite imagery. Already did, but still getting the same error.
Here's my data specification:
  • Sat ID: WV3
  • Band ID: MS1
  • Spec ID: RPC00B
  • Product Level: LV2A
  • Product Type: Standard
  • Radiometric Level: Corrected
  • Radiometric Enhancement: ACOMP
  • Bands: 4 (RGBN)
  • Bits Per Pixel: 16
Here's what I've done so far:
  • Created a mosaic dataset for my images
    • Coordinate System: PRS92 UTM Zone 51N
  • Imported the mosaic dataset as image collection in Ortho Mapping for workspace creation
  • Added raster to my mosaic dataset
    • Raster Type: Raster Dataset
    • Imported a local DEM as Elevation Source in Raster Type Properties
  • Transformation Type: RPC
I've exhausted every possibility I know as far as my knowledge is concern. I would really appreciate if you guys can give me any hints or ideas on how to resolve this.
Thank you very much. 🙂
Rune_Van_Severen
I’m encountering the same issue. Were you able to find a solution?
