IFC Model not Importing Correctly
1156
09-05-2024 07:41 PM
BB34
So when I try to import an IFC model, it comes in as a sort of 2D element for some reason. I have tried different export settings, different revit versions, and importing the revit file vs. the IFC file, and it all does the same thing. I haven't done much with importing models like this before, but it behaves like a normal model only it's flattened. Not sure if this is a revit export issue or an ArcGIS Pro issue.
DA_BIM-GIS
hello @BB34
Are you using the 3D view for your exporter or are you using the plan view ? What are your settings on your exporter ?
David
