Problems creating a relationship for Instant Apps
1265
09-25-2024 03:28 PM
Labels (3)
jewa
Hi, ArcGIS community! I am trying to create a layer that can be voted on and commented on in the Reporter app. However, I'm struggling to create related fields in ArcGIS Pro with my dataset. For one, I can not add Global IDs to my (parent) layer. Since this is not working, I'm not sure what to use as the origin primary key. Then, when I add the table I want to create the relation with, an error pops up that they're not in the same database. I can not figure out where to start when approaching this problem. I've created relationships before, so I'm wondering if something is wrong with the data I'm using. I also have never used the Instant Apps, so there is def a learning curve there 🙂
Thanks for any advice, resources, or suggestions!
PTW
Hello!
This video series is a little different than what you are asking for but it covers adding a GlobalID field to a feature and then a corresponding GlobalID and GUID fields to a table that will hold the collected information. https://www.youtube.com/watch?v=v0W6X6ovi_Q
I hope this helps!
jewa
Took some problem solving, but I got it! The video was very helpful, thank you so much.
