Identify Imagery Date in ArcGIS Pro?
4757
06-21-2019 01:12 PM
FrankPanaro2
Is there a way to use the Explore tool in ArcGIS Pro to identify the date a World Imagery Basemap was captured as you could using the Identify tool in ArcMap? This information seems to be missing in the ArcGIS Pro metadata/popups when selecting a World Imagery basemap. You would think this would be one of THE most important things to include in the metadata and is definitely the main piece of information that people ask for when I create a map for them.
DerekRobillard1
Hi Frank, I realize your post is relatively old, but I was having the same problem and found a solution in Pro v2.6. Maybe it will help...
While in 2D with imagery showing, click the "Explore" drop down arrow and select "Visible Layers". Then when you are using the Explore tool, you can click anywhere on the imagery and the Pop-up window should reveal source info.
FrankPanaro2
Belated thank you lol!
CodaRain23
OK, this is crazy, but this does not work in Pro 3.2. How is this so hard to find?  Any suggestions?
BlueJayinPA
Very belated answer - I was having the same issue in Pro 3.4. I had to reload the Imagery (under Basemap) and that fixed the problem! I can only assume the link I was initially using for ESRI's World Imagery was an older one that lacked functionality.
