I am unable to access arcgis pro
678
01-08-2026 01:12 AM
LutendoNetshipale
Good day
I am unable to log on into arcgis pro software but I can log in to arcgis online.
When I am logging to pro. It says that there are not enough licence available
But I have been added to the licence list
Regards
Lutendo
Tronox KZN sands
DanPatterson
MVP Esteemed Contributor
They will have to contact Tech Support
Esri Support | ArcGIS Technical Support
if you don't have any other contact people in your organization that are authorized to file cases.
... sort of retired...
DanPatterson
You will have to contact the person that manages your licensing to determine your license type, since concurrent use licensing has been deprecated and extra steps may be needed to allow you to get access to Pro for your organization.
ArcGIS Pro licensing—ArcGIS Pro | Documentation
Also confirm how you installed Pro or how it is accessed.
LutendoNetshipale
Thank you for the answer. Our administrator from the organization could not solve it. I do nto not know where to find Arcgis pro technical help.
DanPatterson
