How would you geocode with an address database that didn’t have XY or lat/long info?
3221
02-02-2023 07:21 PM
estev90
Was asked this as part of a pre-interview questionnaire for an analyst position. I’ve only geocoded using address locators off of tables that already had addresses or lat/long info but this question has me stumped. I did think of maybe doing something like a feature to point operation on something like a parcel layer that may contain address data but don’t know if this would be the proper alternative.
Robert_LeClair
Esri Esteemed Contributor
So if the question is how do you geocode without an XY and/or LAT/LONG information in the addrees database, then one presumes that there are addresses in the address database.  If this is true, you have options.
  • Create an address locator in ArcGIS Pro so as to not consume credits using the ArcGIS World Geocoding Service.
  • Run the Geocode Address (Geocoding) GP tool (but can consume credits if you're using the ArcGIS World Geocoding Service) unless you create your own address locator.
Now if there are no addresses, no XY, no LAT/LONG, then the results are a little bit more fuzzy.  You can use ArcGIS Insights, enable location on the address database table, and use Geography.
Hope this helps!
