How to use WITH Clause in Query Layer
1205
10-29-2025 02:41 PM
cjms
I have query that uses common tables via a WITH clause. It works fine in SSMS, but doesn't seem to run in the Add Query Layer tool. Simple example below:
WITH my_cte AS (
    SELECT *
    FROM my_table
SELECT *
FROM my_cte
 Invalid SQL syntax[[Microsoft][ODBC Driver 17 for SQL Server][SQL Server]Incorrect syntax near the keyword 'WITH'.]
Is there some sort of restriction or syntax difference for CTE tables in ArcGIS Pro?
This query is being run against a separate SQL Server 2022 database via an SDE connection, not an Enterprise Geodatabase.
DavidSolari
MVP Regular Contributor
Not sure why that keyword specifically is causing issues but you can rewrite that as:
SELECT a.*
FROM (SELECT * FROM my_table) a
cjms
I'm aware subqueries work. I was just hoping not to have to refactor; I think the CTE looks more readable for longer queries.
JoshuaBixby
MVP Esteemed Contributor
I agree about CTE.  I suggest you submit an ArcGIS Pro Idea to support using CTE with SQL Server query layers.
JeffHaney
I have found table-valued functions to be the best way to sneak non vanilla SQL into Pro.  Lets me use CTEs and things like ROW_NUMBER to create unique ids.
