How To Transfer ArcMap Extensions to ArcGIS Pro
2928
03-29-2021 06:11 AM
pmckinney
Our office is currently using both ArcMap and ArcGIS Pro.  We have a few extensions enabled for ArcMap.  I am trying to figure out how to enable them in ArcGIS Pro.  In the attached image, you can see that License Manager references 10.1-10.7 for the version, which appears to be referencing ArcMap.
We are using concurrent licenses for ArcGIS Pro.  Any ideas/tips/leads on how to enable the extensions for ArcGIS Pro?  Are we able to use the extensions on both platforms?
DanPatterson
MVP Esteemed Contributor
Solved: ArcGIS Pro Extensions licensing clarification - Esri Community although somewhat old deals with the single use vs concurrent use licensing of extensions
... sort of retired...
JayantaPoddar
ArcGIS Pro extensions cannot work with ArcMap extension licenses.
The license keycodes of ArcMap (and its extensions) are different from ArcGIS Pro (and its extensions). Please connect with your local Esri support or check in your My Esri site to obtain the appropriate keycodes for the extensions of ArcGIS Pro.
The authorization process is through ArcGIS License Server Administrator only (For Concurrent-Use licenses).
Think Location
Robert_LeClair
Esri Esteemed Contributor
ArcGIS Desktop extensions work both with ArcMap and ArcGIS Pro.  To enable ArcGIS Desktop licenses for concurrent use, see the following topic here to see how to do this.  If this does not work, please contact Esri Support Services to walk you through the process.
