How to set up hyperlink to attachments
2827
5
10-19-2022 12:31 PM
Labels (3)
dalvarez
Hello!!
The layer I'm working with has a SERVER_PATH and Hyperlink  attributes. I want the values  of the SERVER_PATH (which are different for each asset)  to automatically  go to the end of the hyperlink.  I have all the values for the SERVER_PATH field and have been populating each hyperlink individually. Any ideas on how to do automate this process?
See below picture
Thanks!!
AlfredBaldenweck
MVP Frequent Contributor
There are a few different ways to do this.
  1. Field calculate it to equal the hyperlink+Serverpath (Arcade)
$feature.SERVER_PATH + "\\" +$feature.Hyperlink​
  1. if the url is always the same, then just do whatever the URL is + Serverpath
 "www.exampleURL.com\\" +$feature.Hyperlink​
  • If just for the popup, use the same Arcade expression as the popup and hide the fields you don't need.
AlfredBaldenweck
AlfredBaldenweck
You can also set up an attribute rule for it, but I'm not familiar with how to do that.
Introduction to attribute rules—ArcGIS Pro | Documentation
Create and manage attribute rules—ArcGIS Pro | Documentation
AlfredBaldenweck
Good to hear.
Just a warning, it looks like you're missing a backslash between .org and Traffic
Add in "\\" to the expression to fix the links if they don't work.
dalvarez
Thanks!
this expression worked for me:  "https://wpbgisportal.wpb.org/Traffic/" + $feature.FILE_ + $feature.Hyperlink
A hyperlink was created for every asset
Laura
by MVP Regular Contributor
My issue is backwards - wondering if anyone has insight. I need to create the Server path from the hyperlink
