How to maximize distance between points?
1975
10-27-2021 08:11 PM
Labels (2)
Nico_coral
I have these 12 sites mapped on ArcGIS Pro. I am trying to set up an experiment that has 4 treatments. Since I have 12 sites I was hoping to allocate 3 sites per treatment so 3 replicates per treatment.
I want each replicate per treatment to be as far as possible from one another. Is it possible to calculate this on ArcGIS?
To clarify I am trying to say: Treatment 1 has 3 replicates. From these 12 calculate the three points furthest from each other. For Treatment 2 use the remaining 9 points to calculate the three points furthest from eachother and so forth.
Any help or guidance is greatly appreciated!
Tags (3)
JayantaPoddar
MVP Alum
Here is one way.
1. First, create a copy of the feature class (Feature Class To Feature Class (Conversion)—ArcGIS Pro | Documentation).
2. Select one feature from your original feature class (any corner feature). e.g. MAG-73-9
3. Use Near (Analysis)—ArcGIS Pro | Documentation
Input Feature: The Copy Feature Class
Near Features: The original Feature Class
Method: Geodesic
4. New field will be added to "FC_Copy". Sort the records based on the Distance Field.
Once sorted, assign values to a class field in multiple of 4.
say T-1, T2, T-3, T4, T-1, T-2... repeat.
Think Location
DanPatterson
Generate Near Table (Analysis)—ArcGIS Pro | Documentation
provides a rank as well.  Once you have identified the candidate sites from the table you can go from there since your data set is small (based on the image)
... sort of retired...
