How to make a layout or a map active programmatically using arcpy ?
2120
02-24-2023 11:25 PM
NiharSahoo
I have multiple layout and maps in my project, i want to activate each layout and do some processing like using definition queries on some layers, then create grid using those layer then finally print pdfs. Please advise ?
DanPatterson
MVP Esteemed Contributor
you need to explore the code snippets for the various objects and methods in the python section of the help.
For instance see the code examples in
Layout—ArcGIS Pro | Documentation
... sort of retired...
DuncanHornby
MVP Notable Contributor
Explore the help page that Dan points to and you will see openView().
