How to Format Polygon Symbol via Python?
2789
01-10-2022 06:42 AM
dazu
Is there a way to programmatically access and change the properties of a symbol (or part of it, e.g. pattern agnle) as shown in the window below?
I am aware of the symbol class and its properties.
DanPatterson
MVP Esteemed Contributor
No.  You found CIM.  That is all for python access.
... sort of retired...
DanPatterson
dazu
Wow... that was quick. Thank you, @DanPatterson, for pointing me to Esri's Cartographic Information Model.
The section Additional Resources and Sample Scripts links to the GitHub repository and a sample project with a script to create a dashed effect:
# Author:  Esri
# Date:    March 2020
# Version: ArcGISPro 2.5
# Purpose: This script creates or modifies the dash effects for a line symbol.
# Notes:   - The script is intended to work from a script tool provided with
#            a sample project using "CURRENT".  To see the changes happen be
#            sure to activate the appropriate map or layout.
#          - In addition to this sample script demonstating how the CIM
#            provides access to capabilities not in the managed Python API,
#            is also demonstrates a method for creating CIM objects that are
#            necessary to set desired properties.
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps('Symbology')[0]
l = m.listLayers('States_SingleSymbol')[0]
l_cim = l.getDefinition('V2')         #Get the Layer's CIM definition
#Symbol Level 1 (Solid Stroke)
symLvl1 = l_cim.renderer.symbol.symbol.symbolLayers[0]
#If a dashed effect does not exist, create one
if len(symLvl1.effects) == 0:
  newDash = arcpy.cim.CreateCIMObjectFromClassName('CIMGeometricEffectDashes', 'V2')
  newDash.dashTemplate = [5, 5]
  symLvl1.effects = [newDash]
#If a dashed effects does exist, modify it
else:
  dash = symLvl1.effects[0]
  dash.dashTemplate = [10, 10]
l.setDefinition(l_cim)                #Set the Layer's CIM definition
This serves as a good starting point. Do you know of an easy way to expose the JSON structure of existing symbol styles? Or how to gain insight into the hierarchy?
dazu
help(arcpy.cim)
arcpy.cim.GetJSONForCIMObject(l_cim, "V2")
