How to fill "holes" in Raster / Polygon?
12158
7
04-22-2020 12:29 PM
JosuaInauen
Is there a way to automatically fill such holes which aren't really holes?
Thx in advance!
DanPatterson_Retired
Or for the case being shown...
  • Expand the raster (maybe by 2 cells) the buffer equivalent for rasters, then a
  • Shrink the result of the above by the same amount
This Expand/Shrink sequence can be used to get rid of inner inclusions and exterior fiddly-bits as well.  You can repeat the above overwriting the temporary grids,  It is an alternative to pointing at the screen and saying get rid of that bit
Alena
We use the Fill tool. Spatial Analyst Tools > Hydrology > Fill
DavidPike
MVP Notable Contributor
For a vector, a handy trick is to use the Union geoprocessing tool with only one input and the 'allow gaps' option disabled.  It is however a bit temperamental.
SteveLynch
You could use the Con tool
DavidPike
How would this be implemented Steve? is there some way to look for containment?
JosuaInauen
Many thanks! Exactly what i needed:)
Glad it worked.
