Hi Brains Trust. I'm doing some cleanup work on a road network to make it suitable for Network Analysis, and have come across the following issue. One of the steps I have is usin the Integrate tool to align spatially different datasets. Unfortunately, a side effect of this is that lines passing across each other which normally don't intersect (as in no co-located vertices which Network Analyst uses to permit turns) now do. I've identified a lot of overpass/underpass areas which need to have these no-turn intersections cleaned, but can't find a way to bulk delete vertices when identified by an intersecting polygon. Any ideas out there on how to achieve this?
Below screenshot shows where a route turns off a bridge instead of following along the off ramp.
Hi. Do you have an advanced license? In a nut shell, I use one of these to:
At the time I didn't figure out how to do it without an advanced license, but with some playing around with python, now I have!
Starting data:
1. Convert lines to points using below python code:
import arcpy
# Set paths
input_fc = r"C:\YourProject\YourGDB.gdb\YourPolylineLayer"
output_fc = r"C:\YourProject\YourGDB.gdb\PolylineVertices"
# Use the same spatial reference as the input
spatial_ref = arcpy.Describe(input_fc).spatialReference
# Create output point feature class
arcpy.CreateFeatureclass_management(
out_path=r"C:\YourProject\YourGDB.gdb",
out_name="PolylineVertices",
geometry_type="POINT",
spatial_reference=spatial_ref
# Add a field to track original feature ID (optional)
arcpy.AddField_management(output_fc, "SourceID", "LONG")
# Insert points
with arcpy.da.SearchCursor(input_fc, ["OID@", "SHAPE@"]) as search_cursor, \
arcpy.da.InsertCursor(output_fc, ["SHAPE@", "SourceID"]) as insert_cursor:
for oid, polyline in search_cursor:
for part in polyline:
for point in part:
if point:
insert_cursor.insertRow((point, oid))
2. Use Select by Location to select undesirable points
3. Use Delete Rows to delete selected points
4. Use Points to Line to reconstruct lines from remaining points
Turn that python code into a python tool and you can string that into a model with the rest of the tools to repeat as needed.
Erase Point (Editing)—ArcGIS Pro | Documentation
assuming you aren't talking about manual editing
Close! Yes, I'm not talking manually - that I have well and truly sorted. Trying to automate/script a faster solution for preidentified "issue" intersections.
The Erase Point tool is almost what I need, except I want vertices on a line - not standalone point features.
I've just found this post (https://gis.stackexchange.com/questions/227268/delete-line-vertex-from-polyline-layer-using-point-fe...) that leads me to the Feature Vertices to Points tool, which might have been helpful in a larger convert, select, rebuild process, but I don't have access to an Advanced licence (only Standard).
Also just found this (https://gis.stackexchange.com/questions/227115/remove-polyline-vertex-outside-polygon-in-arcpy) from 5 years ago so will see if I can make it work. I've got a trial of XTools Pro which gives me the Line to Point option, so at least I have something to play with.
@LindsayRaabe_FPCWA did you ever find a solution to this? I have a similar situation with a water distribution network.
Starting data:
import arcpy
# Set paths
# Insert points
for point in part:
if point:
My use case was a little different, but this general workflow worked like a charm! I have a water distribution network where lines cross each other, but aren't actually connected. So I needed to delete all of the vertices where lines intersected where there wasn't actually a point feature connecting them.
So my workflow was basically
This was a really easy way to accomplish this, thanks for the insight!
Glad you found it useful and managed to adapt it to your needs!
