how to delete the overlapping point features in Arcgis pro
3161
12-15-2023 07:27 AM
YuvarajuDhananjay
we have many of these point features in the map, if I use delete identical it deletes other features whose having the same attribute value. can anyone please give an idea on this?
DanPatterson
MVP Esteemed Contributor
If each multipoint group has the same coordinates (x,y, z), then expect them to be deleted.
If the multipoint group doesn't have the same coordinates, then you can't use anything to distinguish them apart except the coordinates.
Delete Identical is working as expected then, not as you want it to
... sort of retired...
DanPatterson
you have Multipoints, Singlepoint would enable you to delete/identify on the shape field
Multipart To Singlepart (Data Management)—ArcGIS Pro | Documentation
YuvarajuDhananjay
but i want those in Multipoints only...
DanPatterson
SalahAlalawi
wonderful, grateful.... appreciated dude
