How to create runtime geodatabase(.geodatabase) from my existing tif files using ArcGIS Pro
1620
09-02-2021 07:15 AM
2xlearner
I want to create .geodatabase file with data in it using ArcGIS Pro. To do that I opened ArcGIS Pro, then create project and open catalog pane. Right click on database and choose to create new mobile geodatabase. But I can not add tif files to runtime geodatabase(.geodatabase) to use .geodatabase file offline in future.
David_Brooks
MVP Regular Contributor
@2xlearner you can't load raster data into Mobile Geodatabases from ArcGIS. The offline workflow is to have a separate TPK (tiled map package) for your raster data.
David
..Maps with no limits..
KimmeSu
How do you create the Runtime .geodatabase files from Pro?
