How to Create MBTiles ?
8187
09-09-2021 11:10 PM
JoelRodriguez
How do I created MBTiles using the Data Interoperability extension in ArcPro? I can't find good instructions anywhere.
DanPatterson
MVP Esteemed Contributor
Are these the documents you have consulted?
Get help for the ArcGIS Data Interoperability extension—ArcGIS Pro | Documentation
The extension is designed to import/export from one format to another, so the actual creation is probably not covered explicitly, other suggestions are to consult the FME workbench or QGIS help documents
... sort of retired...
JoelRodriguez
So I follow some of the Instructions there but when I created a Spatial ETL Tool the Workbench doesn't open.
JayantaPoddar
Working on ArcGIS Pro 2.8.x?
Have you followed the steps in Create an Esri Spatial ETL tool ?
You can start with the creation of an Esri Spatial ETL tool, or create a workflow in FME Workbench (launch from Start button), and refer the FMW file to an ETL toolbox.
*Just checking if ArcGIS Data Interoperability is installed, and license is available.
Think Location
JoelRodriguez
Yes, but when I get to this part
The Workbench application is launched.
The workbench doesn't launch. I did check and I have the extension available, and I installed the .exe file for data interoperability.
