How to create & embed a pie chart ArcGIS Pro
3885
02-01-2024 04:08 PM
AnnaBartnik
Hello, I wish to create a pie chart that represents certain areas on my map and what their sediment composition is made of. When I right click on my csv file and click "Create chart" the pie chart option is not available. I only get options for bar chart, line chart, histogram, scatter plot, and a few others. I have the sediments and their respective percentages within my attribute table. additionally, Id like to make it so that the pie charts are visually on the map. It seems like you can only do this on ArcMap though, not ArcGIS Pro. Any tips or suggestions would be awesome. here is an example of what I would eventually like to see on my map in ArcGIS Pro:
different colors representing different sediment types.
DanPatterson
It appears to be possible
Chart symbology—ArcGIS Pro | Documentation
but you indicate that you are using a csv file.  Perhaps make a featureclass in a file geodatabase first and try on it.
... sort of retired...
ChristopherAllen
Hi @AnnaBartnik ,
Pie charts were introduced in Pro 3.1. If you are on 3.1 or above and do not see the "Pie chart" option under the "Create chart" menu for your CSV file, please let me know.
However, as @DanPatterson mentioned, if your goal is to display charts on a map then you are likely looking for Chart symbology, which is distinct from tabular charts in Pro.
Thanks!
Chris
