How to create a WMS using ArcPro/Server?
2029
04-18-2024 09:05 PM
EdX1
Hello,
How can I set up a WMS (Web Map Service) using data from a SDE? Is it possible?
I have been requested to provide "GetCapabilities link that links to a WMS service" - I'm struggling to find any information on how to do this via google.
Thanks.
MiguelParedes
Greetings @EdX1
Yes, it is possible if you publish a Map Service and enable its WMS capability.  I will assume you want to publish the service to ArcGIS Server and that you will use ArcGIS Pro to do so.
Please, follow the documentation on Publish a map service and then Configure capabilities to select WMS.
I believe you will find the above workflow a good starting point, but let me know if you have further queries about this.
Miguel
MiguelParedes
Greetings @EdX1
Miguel
