How to bypass raise Error in if else statement
174
a month ago
LoriEmersonKDOT
Why does my arcpy code raise an error even though the if/else statement says to bypass it?  For example, why does the raise RouteError still happen when if row[3] == "NO ERROR" is true?
class RouteError(Exception):
    pass
import arcpy
import sys
def CalcPavementArea_tool(in_FC, in_RouteIdx, in_Workspace, in_LRS, out_Poly_Area):
    try:
        # Define workspace using input paramter value
        arcpy.env.workspace = in_Workspace
        my_RouteID_FromTo_Measures_Table = in_Workspace + "\\input_RouteId_FromTo_Measures"
        # Update table with user's RouteId,, From, and To Measures
        fields_inputRoute = ['RouteId', 'FromMeasure', 'ToMeasure']
        with arcpy.da.UpdateCursor(my_RouteID_FromTo_Measures_Table, fields_inputRoute) as cursor:
            for row in cursor:
                #Update RouteId, FromMeasure, ToMeasure values
                row[0] = in_RouteId
                row[1] = in_FromMeasure
                row[2] = in_ToMeasure
                cursor.updateRow(row)
        arcpy.AddMessage("Update to RouteId=" + in_RouteId + ", FromMeasure=" + in_FromMeasure + ", ToMeasure=" + in_ToMeasure + " input table completed successfully")
        # Make Route Event from LRS_County and User's input
        # Make Route Event Layer (Make Route Event Layer) -- from input RouteId, and From/To measure
        output_RouteId_FromToMeasures_Events = "input_RouteId_FromToMeasures Events"
        arcpy.lr.MakeRouteEventLayer(
            in_routes=in_LRS,
            route_id_field="RouteId",
            in_table=my_RouteID_FromTo_Measures_Table,
            in_event_properties="RouteId; LINE; FromMeasure; ToMeasure",
            out_layer=output_RouteId_FromToMeasures_Events,
            add_error_field="ERROR_FIELD",
            add_angle_field="NO_ANGLE_FIELD",
            angle_type="NORMAL",
            complement_angle="ANGLE",
            offset_direction="LEFT",
            point_event_type="POINT")
        arcpy.AddMessage("Make Route Event Layer completed successfully")
        # Verify Route Results -- LOC_ERROR
        myEventFields = ["RouteId", "FromMeasure", "ToMeasure", "LOC_ERROR"]
        with arcpy.da.SearchCursor("input_RouteId_FromToMeasures Events", myEventFields) as srchCursor:
            for row in srchCursor:
                if row[3] == "No Error":
                    arcpy.AddMessage("RouteId=" + str(row[0]) + ": FromMeasure=" + str(row[1]) + " ToMeasure=" + str(row[2]) + " are valid.")
                else:
                    if row[3] == "Measure Extent Out Of Route Measure Range":
                        arcpy.AddWarning("Measure Extent Out Of Route Measure Range. RouteId=" + str(row[0]) + ": FromMeasure=" + str(row[1]) + " ToMeasure=" + str(row[2]))
                    else:
                        arcpy.AddError(row[3] + ". RouteId=" + str(row[0]) + ": FromMeasure=" + str(row[1]) + " ToMeasure=" + str(row[2]))
                        raise RouteError
        # Export the Route Event to a Feature Class
        arcpy.conversion.ExportFeatures(
            out_features=in_Workspace + r"\RouteId_FromToMeasures_Events",
            use_field_alias_as_name="NOT_USE_ALIAS",
            field_mapping=None
        arcpy.AddMessage(in_Workspace + r"\RouteId_FromToMeasures_Events" + " EXPORT completed successfully")
        return
    except RouteError:
        arcpy.AddMessage("Script ended unsuccessfully")
    except arcpy.ExecuteError:
        arcpy.AddMessage(arcpy.GetMessages(2))
    except Exception as e:
        print("Other error:", e)
if __name__ == "__main__":
    ## Grab parameter values and pass to our tool
    in_FC = arcpy.GetParameterAsText(0) # -- feature class
    in_LRS = arcpy.GetParameterAsText(1) # -- LRS
    in_RouteIdx = arcpy.GetParameterAsText(2) # -- RouteId
    in_FromMeasure = arcpy.GetParameterAsText(3)
    in_ToMeasure = arcpy.GetParameterAsText(4)
    in_Workspace = arcpy.GetParameterAsText(5) # -- workspace
    out_Poly_Area = arcpy.GetParameterAsText(6) # -- output polygon
    arcpy.AddMessage(in_RouteIdx)
    arcpy.AddMessage(in_FromMeasure)
    arcpy.AddMessage(in_ToMeasure)
    #arcpy.SetParameterAsText(2, "Result") # -- Output polygon with paved surface area
JoshuaBixby
Beyond Richard's questions, Python string comparisons are case sensitive.  I noticed your code block shows
but your question states, "row[3] == "NO ERROR".  Also, extra space padding in the string can cause an issue.
RichardDaniels
MVP Regular Contributor
do you want the 'except' blocks to flow like that or, if there is an exception, do you want to show the appropriate message and then 'break' out of the try block? Along the lines of:
 except ZeroDivisionError:
    # Handle division by zero
    print("Error: Cannot divide by zero.")
   return None # You could also raise an exception here
JoshuaBixby
