How to add fields to a raster or tiff file
398
07-16-2025 04:11 AM
ckariya2
Hi All
I use ArcGIS Pro. I have a soil classification vector file for my area of interest. The attribute table of this shapefile has several fields, such as shape length, shape area, color code, etc. Some fields were added by me, such as color code. I converted this shapefile to a raster using the "Polygon to raster" tool in ArcGIS Pro. Now, several fields are missing in the attribute table of this raster. I can't add those fields as the "Add" button of the attribute table is inactive. I exported this raster file to a TIFF file ( to a folder and also to the Geodatabase), but still the "Add" button is inactive. Is there a way to add fields to the raster or TIFF file?
Many thanks in advance.
DanPatterson
MVP Esteemed Contributor
you can't add fields to a floating point rasters, only integer rasters
did you try
Add Fields (multiple) (Data Management)—ArcGIS Pro | Documentation
Add Field (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
did you try
ckariya2
Hi Dan
Yes, "Add field" worked.
Many many thanks!
DanPatterson
glad it worked out
