How print nearest object?
1567
04-16-2021 07:23 PM
Radzhabad
I have point on map. I want found nearest object. Code works perfect. System show 1 occurence. But how get it? opori_path element
point = arcpy.Point(5285360.478599999, 5310336.491400003)
ptGeometry = arcpy.PointGeometry(point)
x = arcpy.analysis.Near(ptGeometry, opori_path, None, "NO_LOCATION", "NO_ANGLE", "PLANAR", "NEAR_FID;NEAR_DIST;NEAR_FC")
DanPatterson
MVP Esteemed Contributor
See the second code example
Near (Analysis)—ArcGIS Pro | Documentation
A dictionary is produced with the target and near ids.
In the interim, try
print(x)
to at least see what you have for the value(s) you collected for the near analysis
... sort of retired...
DanPatterson
In the interim, try
print(x)
