I want to create a mosaic dataset with 400 1m pixel size orthophotos. Each image is about 1 GB and 20,000 x 20,000 rows and columns. I created pyramids beforehand. Now I am trying to add these images to a Mosaic Dataset. For hours it just stays at 0% with messages in attached picture. I am using ArcGIS Pro on a 64 GB Xeon processor. Any idea if this will work?
Sincerely
A few questions for you:
1. Are you adding the mosaics to a mosaic dataset in a file or enterprise geodatabase?
2. Is the folder of raw images on a shared network drive or on your C: drive?
3. Is the target geodatabase on your C: drive or a network share?
Hi Robert
Okay - thank you for the details. Let's try this workflow - instead of adding all 400 raster datasets in one operation, break them into smaller groups - say 50 or 100 - and see if the process completes. If so, then load another group of 50 or 100. Repeat the process until all 400 images are added. What is the result?
