How do you find random Lattitude and Longitude points?
1300
6
12-21-2018 05:25 AM
MATTWALLACE
I am attempting to find random Latitude and Longitude points where roads and waters of the state intersect without having to go into the field, how do you do this?
Tags (1)
DanPatterson_Retired
I assume you have a roads layer and a river layer.
Use the Intersect tool in arctoolbox to retrieve the intersection points
MATTWALLACE
Dan,
I am using ArcGIS 10.5.1 I have tried to find the Intersect Tool in the Arc Tool Box but I cant find which heading it is under can you advise?
Matt Wallace
District Technician
Richland Soil and Water Conservation District
Ph: 419-747-8687
Ph: 419-747-8686
Analysis toolbox, overlay toolset, it is there
RobertBorchert
Honored Contributor
Use the intersect Tool as Dan suggested or the Info Tool from the toolbar.  It will give you X,Y location information
the intersect tool will give you a lot the info is one at a time.
JoshuaBixby
MVP Esteemed Contributor
Where does the random part fit in?  The intersection of roads and waters isn't random.  Do you want to find all of them and then select a random subset?
MATTWALLACE
Neil,
The random part comes in when we are looking at culverts and outfalls that empty into what is considered “waters of the state”. I do have a roads layer and a hydrology layer that shows the blue lined streams but they are not always all inclusive. I would like to do as you have suggested below, find them all then select a subset or random subset, how would I accomplish this?
Matt Wallace
District Technician
Ph: 419-747-8687
Ph: 419-747-8686
