How do I symbolize by date (DATE field)?
1959
01-16-2020 12:50 PM
JoshWhite
Honored Contributor
I've seen some posts about symbolizing by date (I find it odd that Esri still hasn't come up with a good way to do this) in ArcMap but I haven't seen anything for Pro.  I cannot figure out a logical way to symbolize by date.  I am working with Collector to collect sidewalk details.  It would be nice to be able to track my progress and I thought doing this by date would be the best way.  I have a last edited date field that would work perfectly.  I could also create a new date field if that autoupdated field is an issue.  I've also considered using the YYYMMDD format in a text field but I would have to enter it like that each time I did an edit which is kind of a pain.  Seems to me that date or time should be a simple way to symbolize something.  Is there something preventing Esri from implementing this?
Josh White, AICP
Principal Planner
City of Arkansas City
MatthewDriscoll
I have never tried it before now, but using unique values in Pro seems to work fine.
JoshWhite
Honored Contributor
Is that a DATE field or a text field with a date in it?  Also, since I am using the last edited field, there would be something like 1100 unique values.  The other thing I can think of is added a field that says updated with a Y or N flag and symbolize it that way.  Not as ideal but it should work for this project.
Josh White, AICP
Principal Planner
MatthewDriscoll
Yes that is using DATE as the attribute data type.
JoshWhite
Honored Contributor
Ah thanks, I guess that really doesn't matter, it seems to deal fine with the unique value renderer but I am still stuck with having too many unique values to do this.  This of course is a polyline so all I really wanted to do was have all lines with an edit date prior to say 2019 be one color and the most recent ones be another color.  Is there a way to do unique values by a range of dates.
Josh White, AICP
Principal Planner
MatthewDriscoll
Yes you can!  Hold shift or control and right click and select Group values.
Make sure to mark a response as correct if one answers your question if one is to your satisfaction please.
