How do I make the legend columns wider?
6220
06-16-2023 12:43 PM
Brenda_Thompson
No matter what font size or fitting strategies I apply, I can't figure out how to allow the label text to remain in the same row -- it keeps splitting my labels into two rows, as if the legend width is super small. How can I allow my legend items to spread across the legend width?
AubriOtis
It sounds like you might have word wrapping turned on for your labels. If you change the word wrapping values to be larger or turn it off altogether your labels should take up more space.
Cheers,
Aubri
AubriOtis
Cheers,
Aubri
Brenda_Thompson
ugh, word wrapping was the culprit! thank you so much
ZenMasterZeke
Right click the legend. This gives a pop up where you can set various properties. For your case, click Properties to open the Elements pane. In the Legend tab, click Show Properties. One of the options in here is 'Keep in single column'.
You can also click the second icon (Arrangement) under Legend and adjust properties there. Play around and see what works for you.
Brenda_Thompson
the issue turned out to be word wrapping that was turned on, though I will use your advice to continue playing with these settings to get better at formatting. I appreciate your reply!
