I have a layout exist where i need to update the text element of the specific maps extent areas generated map series page name ?
I am use the layer name to generate grid and then i have generate the map series using that grid layer.
Now i want to populate the selected areas PageName on my layouts text element after filtering the feature layer for specific area.
below is the code that i have used.
import arcpy,os
# Project object
aprx = arcpy.mp.ArcGISProject("current")
# Map objects
mainMap = aprx.listMaps("Main Map")[0]
overviewMap = aprx.listMaps("Overview Map")[0]
# Layer objects
countriesLayer = mainMap.listLayers("zone")[0]
# Layout object
lyt = aprx.listLayouts()[0]
field_name = "PageName"
l_cim = countriesLayer.getDefinition('V3') #Get layer's CIM / Layer URI
lURI = l_cim.uRI #Needed to specific the index layer
lyt_cim = lyt.getDefinition('V3') #Get Layout's CIM definition
#Create CIM Spatial Map Series Object and populate its properties
ms = arcpy.cim.CreateCIMObjectFromClassName('CIMSpatialMapSeries', 'V3')
ms.enabled = True
ms.mapFrameName = map_frame_name
ms.startingPageNumber = 1
ms.currentPageID = 2
ms.indexLayerURI = lURI #Index layer URI from Layer's CIM
ms.nameField = field_name
ms.sortField = field_name
ms.sortAscending = True
ms.scaleRounding = 50
ms.extentOptions = "BestFit"
ms.marginType = "Percent"
ms.margin = 10
lyt_cim.mapSeries = ms #Set new map series to layout
lyt.setDefinition(lyt_cim) #Set the Layout's CIM definition
#Force a refresh of the layout and its associated panes
# Map Frame objects
mainMapFrame = lyt.listElements('MAPFRAME_ELEMENT',"Main Map Frame")[0]
overviewMapFrame = lyt.listElements('MAPFRAME_ELEMENT',"Overview Map Frame")[0]
finalPDF = r"C:\LPA\PDFs\LayoutFromCursor.pdf"
pdfDoc = arcpy.mp.PDFDocumentCreate(finalPDF)
countriesSortedByNameList = sorted([row[0] for row in arcpy.da.SearchCursor(
countriesLayer,"NAME")])
for pageCount,countryName in enumerate(countriesSortedByNameList[:10]):
countriesLayer.definitionQuery = "NAME = '{0}'".format(countryName)
selCountryExtent = mainMapFrame.getLayerExtent(countriesLayer)
mainMapFrame.camera.setExtent(selCountryExtent)
mainMapFrame.camera.scale = mainMapFrame.camera.scale * 1.05
countriesLayer.definitionQuery = ""
print(countryName)
# Title text object
titleText = lyt.listElements("TEXT_ELEMENT","Page Name")[0]
#### Display PageName of the Map Series ####
#titleText.text = ""
# Export PDF for this country's page
lyt.exportToPDF(r"C:\LPA\PDFs\test{0}.pdf".format(pageCount))
pdfDoc.appendPages(r"C:\LPA\PDFs\test{0}.pdf".format(pageCount))
# Save and close PDF and open in Adobe Acrobat Reader
pdfDoc.saveAndClose()
del pdfDoc
# Delete project object
del aprx
