How do I create a 3D image from x,y,z coordinates?
2317
09-20-2023 12:17 PM
RobertReynolds2
I have x and y cartesian coordinates and elevation values.  I can plot in ArcGIS Pro under the Map tab, then choosing "Add Data", then choosing "Data add data to the map", then selecting the .csv format Excel file.
Under Stand Alone tables, right click, then choose "Display XY Data".
https://ibb.co/mSHnBG0
Spheres are then created at the x,y,z coordinates.
https://ibb.co/C9H5cS7
How can I analyze this set of data so that it is created in a 3-dimensional sphere/amorphous shape instead of a 2-dimensional rectangle (which happens when you use Analysis/Tools/Geoprocessing/IDW (3-D analyst tools)?  Analysis is in a local scene so the viewpoint can be changed using the Navigator.
Analysis would be on a 4th Excel column (conductivity values) using kriging or IDW.
I'd like to see a blob shape with green for low values of conductivity and red for high values - I use the "condition number" color scheme.
https://ibb.co/L8GW2nM
I've experimented with a voxel scale in NetCDF, but it first creates a volumetric box, and then you have to slide a scale from you low values to high values.
