How do I concatenate fields and get results of what I see in the attribute table and not the coded values in the new field created ?
1946
09-30-2021 03:36 PM
markross
 I have created a new field in the attribute table Called "new_labes".
I then right-click on 'new_labels' to open the calculate field tool I  then concatenate other fields such as SAF or SRM in the attribute table.  the result is giving me the Coded name and not the description as it was previously was viewed in the attribution table for  SAF or SRM.
EX:
Before : SAF=pine tree and         After: In new_labels SAF value is seen as 001
I did notice that SAF does have a domain type as coded value domain which 000 = pine tree
how do I concatenate fields and get results of what I see in the attribute table and not the coded values in the new field created new_labels?
UriGilad_EsriAu
Hi @markross,
The GDB's domains have a code and a description. The calculator is grabbing the code instead of the description.
In the field calculator, using Python 3 as Expression Type, use the following code (replace the values in red with the relevant values):
new_labels
getDomain(!SourceField1!, !SourceField2!, 'DomainName')
In the Code Block:
def getDomain(source1FieldCode,source2FieldCode,DomainName):
    gdb = r"yourGDB.gdb"
    dom_desc = [d.codedValues for d in arcpy.da.ListDomains(gdb) if d.name == DomainName][0]
    for code in dom_desc.items():
        if code[0]==source1FieldCode:
            domDescription1 = code[1]
        if code[0]==source2FieldCode:
            domDescription2 = code[1]
    Concat = domDescription1+domDescription2
    return Concat
You can find the domain name in the GDB's domain table.
Hope this helps,
Uri
If this answer solved your question or if you found it helpful please mark it accordingly to help others who have the same question.
markross
Thanks, Uri
The problem I'm still having is how do I use multiple domains? If Field one has one domain ex: "EV_SRM_COVER_TYPE" and field two has a separate domain listed ex: "EV_SAF_COVER_TYPE" in GDB.
Field 1 = !SRM_COVER_TYPE!
Field 2 = !SAF_COVER_TYPE!
the result is still 000-111 after I concatenate but I need the descriptions instead of the code
