I am running ArcGIS Pro 2.6.2.
The text elements in lesson 4, exercise 1 of the Cartography. MOOC are formatted without this space/padding and is what I am trying to achieve.
I have copied and pasted this into my new working layout to determine how it has been configured, however, there appears to be no setting for this.
When I create a new text element in my new working layout, matching all of the text settings between it and the copy from the Cartography MOOC, the space still appears.
Following the methodology in this video, which uses a rectangle text element, did not work either. The text elements still have space.
Thanks in advance.
Did anyone figure out a solution for this? Struggling with it now. Need to remove padding from graphic text.
I requested a case with ESRI technical support about this issue. ESRI looked into it and were unable to provide a solution to remove the padding around graphic text. They responded "unfortunately there isn't a setting that will let you alter the padding." They have requested that I submit a response for their enhancement log. I will be including this issue along with several other layout issues in my response.
Thank you, that is so disappointing. Have you had a response from Esri since submitting a response to them?
Did anyone get a solution to this? It is pretty frustrating when trying to align text to other elements? I am finalizing a template and the padding in the textboxes make things appear to not be exactly lined up when using guides.
Nup, it's still an issue on ArcGIS Pro 3.4.3....
