How can I georeference shapefile in Arcgis Pro?
798
05-22-2023 08:14 PM
AvaiyaJigar
I imported dwg file in Arcgis pro > Georeferenced DWG > Converted DWG to shapefile
Now when I want to correct georeferencing of shapefile but I cant find way to do it.
Tags (1)
DanPatterson
MVP Esteemed Contributor
If the DWG had a specified coordinate system, and it wasn't transfered to the shapefile, did you try the
Define Projection (Data Management)—ArcGIS Pro | Documentation
to specify the coordinate system information?
... sort of retired...
JohannesLindner
MVP Frequent Contributor
Instead of converting to Shapefile and referencing that, do it the other way around:
Load your CAD file, this will be inserted as a group layer.
Select on of the actual layers (eg Multipatch) to activate the CAD-Data ribbon
You can now georeference the CAD file like you would do with imagery. When you're done, you can export to the format of your choice.
https://pro.arcgis.com/en/pro-app/3.0/help/data/cad/georeferencing-cad-data.htm
Have a great day!
Johannes
