¿How can I fix a corrupt project of ArcGIS Pro?
974
07-29-2019 12:39 PM
Jhon_FredyUribe_Oquendo
One of my projects in ArcGIS Pro is corrupt
When I try to open a project in which I used to work it shows an error that cannot be opened. Somebody knows how to fix it? It is very important to save this project because I had there a lot of maps and designs that I really need.
Thanks
PrasantaBhattarai
Hello!
Are you able to share your project with us? We can take a look at it and see if there is anything that could be done to recover the project. You can inbox me towith your project and the information below (as much as possible).
  • Exact error message.
  • Version of ArcGIS Pro the project was originally created.
  • Last saved ArcGIS Pro version.
  • Content of the project (maps, data types, connections, etc)
  • Exact steps carried on the system or in ArcGIS Pro before the project starts to throws this error.
  • If ArcGIS Pro crashed while attempting to save just before the issue started, see if there is an error report generated which is found in C:\Users\<Username>\AppData\Local\ESRI\ErrorReports.
Regards,
Prasanta.
